1991 Ford Bronco Oil Pressure
ROLLINFORDS
Engine Mechanical problem
1991 Ford Bronco V8 Four Wheel Drive Automatic
Once my truck warms up, the oil pressure will drop to redline or lower when I come to a stop. Sometimes it will drop all the way and kill the motor. I can keep it alive by staying on the gas, but from my knowledge this is not a good thing. I am not for sure what it is.
Jul 15, 2010 at 1:39 PM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch after you test the wiring, abnormal could mean oil pump and engine bearings
Jul 15, 2010 at 1:42 PM
