Engine Mechanical problem
1991 Ford Bronco V8 Four Wheel Drive Automatic
Hello i have a 1991 ford brono hwat happened is it had a 302 which ended up getting a rod knock so then i went ahead and found a motor which was a 5.8 windsor i did the swap and got the 5.8 in. it started right up but sounded like it had a miss so i decide to try and change the plugs i did that and lost spark sometime when i changed the plugs not sure what happened so today i took my ignition control module to napa and had them test it and it failed 3 times so i put a new module on and still no spark.. the rotor is turning under the cap and i hear the fuel pump when i turn the key on. i put a new ignition coil on and it still didnt run. does anyone know how to test a ignition coil? or have any other ideas thanks
Jul 22, 2008 at 7:28 AM
