1991 Ford Bronco fuel problem
100,351 MILES • V8 • 4WD • AUTOMATIC
JEREMY87
I recently bought a truck from a close friend.it is a 1991 ford bronco 4wd with the 5.0 in it.it has a rebuilt motor and transmission both with about 20k miles.when i purchased the truck it ran perfect.the truck had been sitting for a while though about 5 months.i tried to start it and it will crank over for about 1 min and then die.i drained all of the fuel out of it and added fresh fuel to it.still had the same problem so i replaced the fuel filter and still have the same problem.i was also told there could be air in the fuel lines so i tried to bleed the lines using the release valve on the fuel rail and still no start.i took the front fuel line off of the fuel filter and turned the key to the on position to see if the pump was pushing fuel through the lines and it squirted out.i am out of ideas.the only other thing i can think of is the injectors are clogged is there any way of cleaning them without the motor running?any other ideas would be gratly appreciated.jeremy
Sep 23, 2008 at 7:50 AM
CWHIT114
  • 8 POSTS
when you turn the key do you hear the fuel pump turn on to prime the lines. and does it turn back off after 3 seconds
Sep 29, 2008 at 1:45 AM
