1991 Ford Bronco Fuel
1991 FORD BRONCO
146,000 MILES • V8 • 4WD • AUTOMATIC
ADT0219
After Bronco warms up some, I'll sit at a stop light for a few minutes, then when I give it gas it cuts off, starts right back up and goes on. There is a little hesitation before it cuts off. What seems to be the problem. I've cleaned the throttle body and oxygen sensor, put a new fuel filter on, still has the problem. Help!!!
Mar 10, 2009 at 3:20 AM
MIKE H R
  • 3,094 POSTS
ther may be some junk in the injectors. try some injector cleaner and see how it does.
Mar 17, 2009 at 3:33 AM
