1991 Ford Bronco Electronic Control Module
1991 FORD BRONCO
JUSTINSWAFFORD
Electrical problem
1991 Ford Bronco V8 Four Wheel Drive Automatic
This sounds stupid but where is the Ecm located on my 91 Ford Bronco? Its 302 5.0L Eddie Bauer Edition. Thank you
Dec 26, 2008 at 11:36 AM
  • 54,837 POSTS
Hi, the ECM is normaly located at the near the ebrake lever, the harness comes to the fire wall and is disconnected from there, the mounting bolts are under the hood as well. but he ECM is removed from under the dash near the ebrake lever. please let me know.
Dec 26, 2008 at 12:38 PM
TRAVIS650D
  • 8 POSTS
Your right but to be a little more clear. Its behind the kick panel, you have to pull out the plastic clips to get the panel off .. But I would disconnect the wiring harness first. Thats under the hood. on the drivers side. Its a rectangular object, that is to the right of the main (round) wiring harness. It has one bolt that you have to remove to seperate it from the wiring harness. Then remove the panel on the inside of the vehicle. You should see one bolt holding the computer in place. Reverse the order to install.. I hope that helps.. And i hope i didn't step out of line by putting in my two cents, so to speak...
Jan 17, 2009 at 10:42 AM
JUSTINSWAFFORD
Ya thanks for your knowlegde. Found it but i have different problems now. Thanks
Jan 19, 2009 at 12:30 AM
