1991 Ford Bronco dash switch for rear window
125,000 MILES • V8 • 4WD • AUTOMATIC
BARRY HUGGINS
the only way i can get the back window down is to use the key in the switch on tailgate. i can't get the swtch on dash to do anything. where is a good place to start?
Feb 5, 2008 at 2:28 PM
JWALTH02
  • 180 POSTS
Pull off the dash and with a volt meter test to see if you're getting power to the switch. If you are and it doesn't work start by replacing the switch.
Feb 6, 2008 at 6:31 PM
