1991 Ford Bronco back brake drum
1991 FORD BRONCO
150,000 MILES • V8 • 4WD • AUTOMATIC
NATECHRISTOPHER
my drivers side back brake is locked to the drum and i cant get it off any suggestions how?
May 16, 2010 at 9:20 AM
TOOOMANYTOYS
  • 513 POSTS
You can try to use a brake spoon (flat head screwdriver) on the adjuster and loosen the tension on shoes. If it still will not come off you may need to get a puller big enough to fit onto drum.
May 16, 2010 at 9:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
may need to use flat screwdriver to adjust the lever through backing plate. also ensure park brake is not engaged
May 16, 2010 at 9:29 AM
