1991 Ford Bronco 91 Bronco trouble running when wet
115,000 MILES • V8 • 4WD • AUTOMATIC
PENZFAN11
  • 5 POSTS
My 91 Bronco, 5.8L V8, 4x4, 115,000 miles seems to have problems starting and running in wet weather. I just bought it 3 weeks ago and this has already happened twice.
It sits outside and if it rains or is foggy overnight this is how my morning goes: starts fine, runs for about 1 minute then stalls. It will turn over after that, but it will not fire. The first time it happened I took it to my mechanic and after it sat in his garage for a day or two (and dried out) it started and ran fine. Cold weather doesn't seem to bother it, but wet weather does.
If it's an electrical problem, why will it start, stall, then not start again?
Jan 28, 2009 at 12:36 PM
BMRFIXIT
  • 19,053 POSTS
TUNE UP ?
need to have the tune up checked on it cap rotor and wires
check the coil and its connector
bad distributor cap will do it
Jan 28, 2009 at 9:56 PM
PENZFAN11
  • 5 POSTS
If it was wires, dist. cap, coil etc., why would it start the first time then run for a minute before it stalls?
Jan 29, 2009 at 1:05 AM
