1991 ford bronco 5.0 302 EFI
JACKED91BRONCO
I just bought a 1991 Ford bronco with a 302EFI in it, it has 160 thousand miles. When i looked at it at the guys house i started it and let it run for about 20 minutes, then i took it around the block and everything seemed good so i bought it. Well when i got it home i started it up, backed it off the trailer and then shut it off. Well about a week later i started it and i was working on my tailgate and it stalled, and it wants to turn over but it won't. I changed the fuel filter but that wasn't the problem.
Feb 11, 2007 at 1:55 AM
ROGER MILLER
  • 12 POSTS
more information please, "it wants to turn over but it won't"...... is the engine actually cranking? if not why not? bad batt. , bad starter, corroded connections, siezed motor; if it is cranking have you checked for spark at the spark plugs? test and verify what problem actually is
Feb 11, 2007 at 10:43 AM
JACKED91BRONCO
Yeah it was cranking but it wasn't getting spark i tested it, come to find out it was the ignition module was bad, but i replaced it this morning and it runs fine.
Feb 12, 2007 at 12:55 PM
