1990 Ford Bronco won't start
95,000 MILES • V8 • 4WD • AUTOMATIC
KATHLEEN PAYTON
Car sat not running for 2 years. Was in a small accident, passenger side damage. No brakes or power steering.
Removed old gas, replaced fuel pump,replaced float in tank, cleaned injectors,replaced pressure regulator, fuel filter,
Won't start. Help
Jan 27, 2008 at 2:10 AM
MERLIN2021
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
Jan 27, 2008 at 2:16 AM
