1990 Ford Bronco won't start
KATHLEEN PAYTON
  • 1990 FORD BRONCO
  • V8
  • 4WD
  • 95,000 MILES
Car sat not running for 2 years. Was in a small accident, passenger side damage. No brakes or power steering.
Removed old gas, replaced fuel pump, replaced float in tank, cleaned injectors, replaced pressure regulator, fuel filter,
Won't start. Help
Sunday, January 27th, 2008 AT 10:10 AM
MERLIN2021
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
Sunday, January 27th, 2008 AT 10:16 AM
