1990 Ford Bronco waterpump replacement
95,000 MILES • V8 • 4WD • AUTOMATIC
LOVERBOI4848
im getting different quotes on how much it is to replace the waterpump. do i need to remove the motor or transmission to replace it? Can i do it myself?
Aug 10, 2010 at 1:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
to remove and replace water pump on the V8 model Bronco, will take around 2 hours, approx. $125 labor & $100 parts. neither the motor or tranny have to be removed,the radiator may need removed for access though.
Aug 10, 2010 at 3:29 PM
