1990 Ford Bronco water pump
ROBERT HICKS
Other Category problem
1990 Ford Bronco V8 Four Wheel Drive Automatic 187.oo miles
how to remove the water pump
Dec 5, 2007 at 11:11 AM
JWALTH02
  • 180 POSTS
First you want to remove your fan, then the serpentine belt, then drain your radiator and remove the hoses from the pump. Be sure to have the drain pan under you when you do this since it will still have coolant in it.
Then there are seven or eight bolts I believe to remove and with a little effort it should come free of the gasket. Good luck, hope this helps.
Dec 6, 2007 at 3:38 PM
