1990 Ford Bronco starting issue
200,000 MILES • V8 • 4WD • AUTOMATIC
NOLO0129
I turned the key and it crunk right up, when i let the key go the starter was still spinning like i was still trying to crank it. So i turned the key off and took it out but it was still trying to crank. I am thinking ignition switch. What do you guys think? How hard will it be to fix?
Jun 15, 2010 at 3:54 PM
HMAC300
  • 48,601 POSTS
check your solenoid for sticking or the starter drive is hanging up. The most it will cost you is a starter.
Jun 19, 2010 at 1:20 AM
