1990 Ford Bronco starting
168,000 MILES • 6 CYL • 2WD • AUTOMATIC
HRNS44
i have a bronco 2 at times it will not start i can smell gas like it is flooding out i was told it could be the fuel pump it cranks over just fine but wont start once it does it may go a month without doing it again please help me out i love this ole truck
Apr 12, 2008 at 2:11 PM
BMRFIXIT
  • 19,053 POSTS
if you smell gas while you cranking then the pump is pumping (may be )
you need to check for spark '
and if you have spark then check fuel pressure
let me know you its missing
Apr 12, 2008 at 2:39 PM
