1990 Ford Bronco starter motor isnt hitty flywheel correctl
60,000 MILES • 6 CYL • 4WD • MANUAL
RANGERSGT01
I have changed the hydralic clutch and installed a different engine,the starter which is the same that was in the original isnt engageing the flywhell correctly and is grinding.
Jan 18, 2010 at 10:02 AM
  • 75,988 POSTS
Sounds like the starter pinion drive is too far from the flywheel and needs shimming. Investigate the flywheel thru the inspection plate and verify if its the correct starter-
Jan 18, 2010 at 10:19 AM
