1990 Ford Bronco starter motor isnt hitty flywheel correctl
1990 FORD BRONCO
60,000 MILES • 6 CYL • 4WD • MANUAL
RANGERSGT01
I have changed the hydralic clutch and installed a different engine,the starter which is the same that was in the original isnt engageing the flywhell correctly and is grinding.
Jan 18, 2010 at 6:02 PM
Sounds like the starter pinion drive is too far from the flywheel and needs shimming. Investigate the flywheel thru the inspection plate and verify if its the correct starter-
Jan 18, 2010 at 6:19 PM
