1990 Ford Bronco start problem
117,000 MILES • V8 • 4WD • AUTOMATIC
MTVIEW8
I cannot get the ignition switch to engage the starte r but can crank engine at solenoid.Still does not start. This happened all of a sudden.
Dec 16, 2007 at 9:49 PM
  • 75,988 POSTS
Test the starter relay, neutral safety switch and igniton switch.
Do this hold key to start position and look for power at S terminal at relay-no power there look at the NSS white and pink wire no power there, the problem is coming from the ignition switch.
Dec 16, 2007 at 10:06 PM
