1990 Ford Bronco runs rough
170,000 MILES • V8 • 4WD • AUTOMATIC
RUSTY55
I just got this bronco from a neighbor of mine and it wasn't running and it had been sitting for quite a while and I got it running but now it runs really rough and shakes alot when it idles. I think that the spark plugs wires might be on wrong so if you could send me some diagram to show me how they go from plug to distributor for a 5.0 that would be great and also if you had any other ideas as to what it might be that would be great to. Thanks
Feb 9, 2008 at 3:26 AM
2CARPRO JACK
  • 11,533 POSTS
Firing order is 1 5 4 2 6 3 7 8, in a counter-clockwise rotation
Cylinders are numbered 1 2 3 4 pass side and 5 6 7 8 drivers side
Number one should be marked on the cap. You might have a stuck injector, seen that before when something sits for a long time
Feb 10, 2008 at 12:35 AM
RUSTY55
[quote:98dcf697f7="2CarPro Jack"]Firing order is 1 5 4 2 6 3 7 8, in a counter-clockwise rotation
Number one should be marked on the cap. You might have a stuck injector, seen that before when something sits for a long time[/quote:98dcf697f7]
This firing order didn't work now it wont start at all.
Feb 10, 2008 at 8:43 AM
2CARPRO JACK
  • 11,533 POSTS
Is it a HO 5.0? then it is
1 3 7 2 6 5 4 8
same as a 5.8 L the cylinders are numbered the same
Feb 10, 2008 at 11:07 PM
