1990 Ford Bronco reverse
RCAWTHON
Transmission problem
1990 Ford Bronco 6 cyl Four Wheel Drive Automatic
It goes in reverse but it will not move,i can step on the gas and it will move alittle but seems like something is holding it back
Dec 28, 2008 at 1:30 AM
BILLYMAC
  • 2,204 POSTS
check rear brakes make sure they are free. there is two adjustments on the transmission one rside rear one left front. these are band adjustments. loosen the locknuts you will need a small torque wrench and a adaptor you can weld two sockets together to make this tool.tighten them to 10 ft lbs and tighten lock nuts. if this don,t cure the prob you will need trans repair or a used trans billymac
Jan 11, 2009 at 2:14 PM
