1990 Ford Bronco replacing radiator & water pump
1990 FORD BRONCO
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
SPAULDINGJ88
what else should i replace while i am at it? ie, hoses, fan, fan clutch, thermostate, belts......(i am replacing the water pump and radiator
Sep 10, 2010 at 10:28 AM
  • 110,240 POSTS
If the hoses are old, I would recommend them. Also, while you are at it, the thermostat is right there, so it would be a good idea. Make sure to flush the engine block too as well as back flush the heater core.
Oct 15, 2010 at 3:44 PM
