1990 Ford Bronco 6 cyl Four Wheel Drive Automatic
i recently had to replace what i was told was the transmission cable running from my accelerator pedal to my transmission because it was resting on the exhaust manifold which melted the outer coating exposing the wire which in turn caused my bronco to over rev dramatically at low speeds. I replaced it with a newer cable and it did well the first time out but then it started over revving at low speeds again and the cable is still in pristine condition can you help me?
Aug 22, 2008 at 5:27 AM
