When driving, all is good. When at a stop light, in drive, oil light comes on, obvious overheating occurs due to smell. Put the car in park, even stopped in traffic, and oil light goes off, smell subsides. Oil is leaking, not always obvious by overnight stains on driveway. Current mechanic says oil pan needs to be replaced, including labor, some $2500 (labor intensive) should solve the problem. Hometown mechanic, 3000 miles away, though not a Bronco expert does not agree, says it should be most likely the oil pump, maybe thermostat......and certainly disagrees with a $2500 oil pan repair. Who do I trust?
Oct 6, 2009 at 10:29 AM
