Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Bronco
General
Noises
Tap
1990 Ford Bronco Oil drain plug
1990 FORD BRONCO
309,000 MILES • V8 • 4WD • AUTOMATIC
BOB2
MEMBER
1 POST
oil drain plug won't catch threads, will tapping the hole work, or is it best just to get a new pan?
Jun 8, 2008 at 4:30 AM
BLACKOP555
Experienced Mechanic
you can tap it and hope for the best, if its bad enough you will have to have a plug welded on it and a new drain port installed.
Jun 8, 2008 at 6:18 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
