i have a 1990 ford bronco 302 V8 it starts fine but when it drops to the low idle after start up it begines loping what can i do to fix it
Oct 12, 2008 at 12:17 PM
✓ASE Certified Mechanic
When was the last tune-up? Check the fuel pressure/idle air control valve/motor, throttle position sensor/MAF/MAP sensor/s-PCV and EGR valves
Oct 12, 2008 at 12:53 PM
