My son's 1990 Ford Bronco picks and chooses when it wants to start. When turning the key, it sometimes does nothing and sometimes starts the motor. I do hear the switch above the left wheel well click when the key is turned. I do not hear any noise coming from the starter relay on the right fenderwell next to the battery when the key is turned. Recently, the starter was stuck in the crank position and the battery cable had to be disconnected before it burned up. The truck has started since with no strange noises coming from the starter. I have not been able to locate a spot in which any wires are grounding on metal. Any help is greatly appreciated.
Oct 11, 2008 at 9:48 AM
