1990 Ford Bronco idle speed
219,000 MILES • V8 • 4WD • AUTOMATIC
BAMAPEARL
my bronco started idling at 1400 rpms. I cleaned to IAC valve and butterflys with carb and choke cleaner now it idles at 2000 rpms. Cannot find a vac leak no loose connections what can I do
Nov 9, 2009 at 9:28 AM
  • 75,988 POSTS
Hi bamapearl and TY for the donation
If the IACV and passages is thoroughly cleaned out-inspect for a sticking throttle plate and kinked cable to include testing the throttle position sensor. Check the IACV if its moving in and out
Nov 9, 2009 at 9:34 AM
