1990 Ford Bronco fuel pump just quit but still workss
BRONCOBILLY
MEMBER
1990 FORD BRONCO
Electrical problem
1990 Ford Bronco V8 Four Wheel Drive Manual
no juice to pump plug-in. Is there a pump wire up between th battery and the inner-fender in that mess of wires
Monday, January 26th, 2009 AT 12:58 PM
BLACKOP555
MECHANIC
That mess of wires your refering too, is that the fusible link?
There should be power at the fuse, the relay, the inertia switch, if you have dual tanks there shoudl be power at the switch, and there should be power at the pump.
