1990 Ford Bronco fuel ?
17,000 MILES • V8 • 4WD • AUTOMATIC
MIKE DOTS
i have a 90 bronco 351, after sits all nite i try starting it.after 20 or so mins of turning the swith on and off it will finally start.i replaced fuel pump rely ,,reg,filter i noticed that while doing my morning thing the pump keeps running like trying to prime ? after it starts,it starts right upo every time rest of day.please help.thank you
May 25, 2010 at 2:22 AM
  • 75,988 POSTS
Check your fuel pressure to rule out a failing fuel pump and also test the ignition switch
May 25, 2010 at 1:15 PM
