1990 Ford Bronco Exhaust Leak
1990 FORD BRONCO
101,000 MILES • V8 • 4WD • AUTOMATIC
FUHERJK
Replaced exhaust manifold gaskets but I still have a severe exhaust leak on the passenger side. Manifold did not show any signs of cracks. What could be causing the leak?
Dec 9, 2007 at 1:52 PM
BMRFIXIT
  • 19,053 POSTS
[quote:a3f73dc15d="fuherjk"]Engine problem
1990 Ford Bronco V8 Four Wheel Drive Automatic 101000 miles
Replaced exhaust manifold gaskets but I still have a severe exhaust leak on the passenger side. Manifold did not show any signs of cracks. What could be causing the leak?[/quote:a3f73dc15d]
Check the air tube at the back of the engine
connecting the two heads together
Dec 9, 2007 at 2:23 PM
BRONCOLOVER
  • 15 POSTS
Hi, I just installed an after market exhaust on my bronco 351 and I'm having a leak from the same side, I looked by my transmission on the passenger side and there's a metal tube that's sitting on the lip of the tranny pan that leads to the back of the engine. Is this supposed to be connected to the engine? Also he did not put an o2 sensor on it, is that going to affect my engine?
Dec 9, 2007 at 2:35 PM
BMRFIXIT
  • 19,053 POSTS
[quote:635fc6dfa0="broncolover"]Hi, I just installed an after market exhaust on my bronco 351 and I'm having a leak from the same side, I looked by my transmission on the passenger side and there's a metal tube that's sitting on the lip of the tranny pan that leads to the back of the engine. Is this supposed to be connected to the engine? Also he did not put an o2 sensor on it, is that going to affect my engine?[/quote:635fc6dfa0]
what year is the bronco
it is the EGR tube
if it had an o2 sensor you should put it back
but some of the after market manifold comes with little extra holes and plugs to make them fit more years and model car and truck universal
Dec 11, 2007 at 5:38 AM
