1990 Ford Bronco EFI regulator
ZCHRZ
  • 1990 FORD BRONCO
Engine Mechanical problem
1990 Ford Bronco V8 Four Wheel Drive Automatic
My 1990 5.8L V8 bronco is not starting. There is no fuel pressure when the bleed off valve is depressed. When the pump is activated it sends healthy volume of gas through the filter but never all the way to the injectors to start the truck. Is this a fuel regulator problem? A clogged or leaking injector? Seal problem? And when can I find a diagram of where the lines are run I cannot find the return line to pinch to see if the regulator is stuck open.
Monday, March 29th, 2010 AT 6:36 PM
  • 109,959 POSTS
Pull the vacuum hose off the regulator and see if there is any gas in the vacuum hose. Also, if fuel is getting through the filter, then it has to make it to the injectors. Are you sure the injectors are working?
Tuesday, April 20th, 2010 AT 1:42 PM
