1990 Ford Bronco code 34
1990 FORD BRONCO
190,000 MILES • V8 • 4WD • AUTOMATIC
LACUCARACHALOCO
1990 Bronco, 5.8 efi, e4od automatic, 190000 miles.
I've been getting a 34 trouble code when I use my obd1 scanner. Now most manuals say this is a voltage problem but a mechanic I consulted says I need to replace the egr valve. If it is the egr valve, I can do that myself. If it's some electrical problem then I'm at a loss because electrical has never been my strong suit. I really need to know what I'm looking at here and how to fix it.
thanks
Feb 19, 2008 at 4:31 AM
DTC 34 No EGR flow.
Find it and open it up and investigate could be all carboned-up
Feb 19, 2008 at 5:10 AM
