1990 Ford Bronco BRAKE PEDAL GOES TO FLOOR WHEN STARTED.
130,000 MILES • V8 • 4WD • AUTOMATIC
SCOTH
I'VE REPLACED FRONT CALIPERS,BRAKE LINES,MASTER CYL., VACUUM BLED ENTIRE SYSTEM WITH OVER 3 QUARTS OF DOT 3/4 SYNTHETIC FLUID AND HAVE NO LEAKS. THE VACUUM POWER ASSIST SEAMS TO BE O.K. THE PEDAL IS HARD WHEN NOT RUNNING.
May 11, 2010 at 8:28 AM
2CARPRO JACK
  • 11,533 POSTS
Does this vehicle have RWAL (rear wheel anti-lock)? Sounds like the RABS (Rear anti-lcok brake system) valve is bypassing.I have seen a lot of these go bad, it acts just like amaster cylinder or air in the system.Even when the valve goes bad, it wont set an ABS light every time.
May 11, 2010 at 1:49 PM
SCOTH
the bronco does not have RWAL OR ABS.
May 12, 2010 at 3:07 AM
2CARPRO JACK
  • 11,533 POSTS
Ok, just wanted to be sure, I looked it up before in Mitchell and it said it had it.Did you bleed the wheels in the proper sequence? ; R/R, L/R, R/F, L/F? Did you match the master cylinder up with the old one? was this the reason it was replaced? Are the rear brakes adjusted up properly?
May 12, 2010 at 2:35 PM
