1990 Ford Bronco Brake loss
DACASEY7
Brakes problem
1990 Ford Bronco 6 cyl Four Wheel Drive Automatic
My brake petal went to the floor suddenly I pumped my brakes several times did get the ability to break but would have to keep doing it to be able to stop. It also would pull to the left. Is this wheel/brake cylinder (rear) or is it front left wheel bearings? Can you give a high to low estimate of cost? I'm unemployed and do'nt want to be taken advantage of by repair person. Thanks for your help.
Jul 31, 2010 at 10:39 AM
  • 31,937 POSTS
Hi there,
can you check for any fluid loss at each brake, you should be able to see easily if there is a leak, check the fluid level and top up if low, please advise if fluid is low or not.
mark (mhpautos)
Jul 31, 2010 at 12:38 PM
