1990 Ford Bronco BRAKE LIGHT SWITCH
DARANAJ
Brakes problem
1990 Ford Bronco V8 Four Wheel Drive Automatic
I recently purchased a 90 ford bronco. The truck is missing a brake light switch on the brake pedal. I bought a new one however I do not know hoe to install it.
Feb 26, 2010 at 7:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Lift the locking tab on the switch connector and disconnect the wiring. Remove the hairpin retainer, slide the stop lamp switch, pushrod and nylon washer off of the pedal. Remove the washer, then the switch by sliding it up or down. On trucks equipped with speed control (cruise control) , the spacer washer is replaced by the dump valve adapter washer. To install the switch, position it so that the U-shaped side is nearest the pedal and directly over/under the pin. Slide the switch up or down, trapping the master cylinder pushrod and bushing between the switch side plates. Push the switch and pushrod assembly firmly towards the brake pedal arm. Assemble the outside white plastic washer to the pin and install the hairpin retainer. CAUTION Don't substitute any other type of retainer. Use only the Ford specified hairpin retainer. Assemble the connector on the switch. Check stop lamp operation. CAUTION Make sure that the stop lamp switch wiring has sufficient travel during a full pedal stroke!
https://images.2carpros.com/forum/automotive_pictures/261618_1_133.jpg
Feb 26, 2010 at 7:41 AM
DARANAJ
Thanks the job is done. However my passenger side brake light is not coming on. I checked the bulb and its good. what might the problem be now?
Feb 26, 2010 at 9:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
may have bad wiring to that taillight, it may have a short in it which could be why the previous owner decided to remove the brake switch instead of fix the issue.
Feb 26, 2010 at 12:08 PM
