1990 Ford Bronco Battery Indicator Light
1990 FORD BRONCO
125,000 MILES • V8 • 4WD • AUTOMATIC
SCOTT90FSB
Aloha car gurus:
I could use some help please. The battery indicator on my recently purchased and heavily used 90 FSB remains on with dash showing voltage way to the left of center. I replaced battery and alternator. Indicator still on and dash still showing same. I would appreciate any assistance.....Mahalo in advance.
-scott
Aug 27, 2009 at 6:37 AM
Greetings from Guam
Hey Kanaka, maybe you do this bra disconnect the the wiring connector on the voltage regulator over at the kind front of right fender apron. Take small wire jumper A to F if light goes off-the kind voltage regulator no good. Let me know-
Aug 27, 2009 at 11:18 AM
