1990 Ford Bronco Battery Drain
1990 FORD BRONCO
118,500 MILES • V8 • 4WD • AUTOMATIC
MNL0318
Just bought 1990 Bronco w/351. Thought alt was bad so I replaced it. After replacing alt. I charged battery all night, came back this evening and battery was dead. Had battery load tested, and it tested good. What might be drawing the battery down in such a short time?
Mar 5, 2009 at 8:29 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Hello
Many things can cause an electric draw. You will need to search your vehicle carefully to find it. Interior lights, glove compartment lights, etc.. will all drain a battery quickly and is sometimes hard to notice. More information about why your battery may be draining can be found at the link below..
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
Thanks for using 2CarPros.com!
Mar 5, 2009 at 9:49 PM
