1990 Ford Bronco Battery
JIM KINARD
1990 Ford Bronco
Dead battery: Under warranty no charge.
Next morning dead battery: Returned no charge.
Next day dead battery. Confused?
My Bronco II was driven only to pull it in and out of the garage. What could be the problem?
Jim
Feb 1, 2009 at 4:17 AM
DOCFIXIT
  • 18,828 POSTS
Got a humungous drain my bet is alt. Does batt term spark when you hookup? if yes see if alt gets warm with key off. If yes then diodes in alt. faulty
Feb 2, 2009 at 3:00 AM
KARENCAREN
  • 72 POSTS
Did you check the alternator dude. Maybe your battery is not charging while your engine is on.
Feb 5, 2009 at 4:08 PM
DOCFIXIT
  • 18,828 POSTS
Good idea I assumed that had been done. But start with the basics I violated my rule.
Feb 6, 2009 at 7:37 AM
