1990 Ford Bronco Hard Start Stalls
CARRACER302003
i have a 1990 ford bronco and i am having a serious problem with it cutting out running like crap, it dosent do it all the time its just when you go to start it up it takes for ever ( wich it should not because it has not in the past and it is fuel injected) and when you get on the throttle it falls on its face, and as of now it will not start and when turning it over i smell gas fumes extreemly bad and the fuel press regulator has been replaced just for the info thanks
Jul 11, 2007 at 2:11 PM
MERLIN2021
  • 17,250 POSTS
try the temp sensor...
Jul 21, 2007 at 7:00 AM
JPN1212
[quote:4f257f9a29="merlin2021"]try the temp sensor...[/quote:4f257f9a29]
ive had a similar problem, you mean the temperature sensor for the engine?
May 18, 2008 at 12:34 PM
MERLIN2021
  • 17,250 POSTS
Yes it's usually the Engine coolant temp sensor(ECT) or thie Intake air temp sensor, (IAT)
May 20, 2008 at 6:33 AM
Suggested Repair
Check the engine coolant temperature sensor (ECT) and the intake air temperature sensor (IAT). A faulty sensor can cause hard starting, poor throttle response, and a rich fuel smell.
Conversation Summary
The owner of a 1990 Ford Bronco reports intermittent hard starting, poor running, loss of power under throttle, and a strong fuel smell while cranking. The fuel pressure regulator was already replaced. An expert suggested checking the engine coolant temperature sensor or the intake air temperature sensor.
