1989 Ford Bronco what is the firing order
999,999 MILES • V8 • 4WD • AUTOMATIC
DOYLE111
need to know what is the firing order on a 1989 ford bronco full size
Dec 28, 2008 at 2:39 AM
BUDDYCRAIGG
  • 2,262 POSTS
The front passenger spark plug is #1
and the plugs are 1234 on that side.
The plugs on the drivers side is 5678.
The rotor turns counter clockwise
If you have a 5.0
The firing order is 15426378
If you have a 5.7 everything is the same except the firing order is
13726548
Dec 28, 2008 at 9:22 AM
