1989 Ford Bronco Voltage gauge jumps with everything
1989 FORD BRONCO
212,000 MILES • V8 • 4WD • AUTOMATIC
ALASKABOY
I notice that the battery charge gauge does not stay still.
With engine running, it goes up & down about .2 volts with every blink of the blinkers. It drops about 1 or 2 volts when the lights are turned on, then goes back up when turned off. In all my other rigs (Fords) the charge gauge stays constant in the same situations.
What is this a symptom of?
Battery?
Voltage Regulator?
Alternator?
Ground/short?
Something else?
Thanks!
John in Alaska
May 22, 2009 at 8:43 AM
  • 110,244 POSTS
John:
If the gauge isn't droping or raising out of the normal range, chances are it is just recognizing a change in voltage.
If you want, make sure the ground to the engine block is clean and tight. Also, you may want to have the alt tested. Most nationally recognized parts stores will do it for free, so there is no money out of pocket. The voltage regulator may be starting to go bad, but again, as long as you are in the safe range, I wouldn't be too concerned.
Jun 4, 2009 at 3:21 PM
