I notice that the battery charge gauge does not stay still.
With engine running, it goes up & down about .2 volts with every blink of the blinkers. It drops about 1 or 2 volts when the lights are turned on, then goes back up when turned off. In all my other rigs (Fords) the charge gauge stays constant in the same situations.
What is this a symptom of?
Battery?
Voltage Regulator?
Alternator?
Ground/short?
Something else?
Thanks!
John in Alaska
Battery?
Voltage Regulator?
Alternator?
Ground/short?
Something else?
Thanks!
John in Alaska
May 22, 2009 at 8:43 AM
