1989 Ford Bronco vacuum
1989 FORD BRONCO
93,000 MILES • V8 • 4WD • AUTOMATIC
MIKEM367
  • 10 POSTS
What is the proper engine vacuum at idle? I have a rough idle and the vacuum is running about 17-18in at idle. What should it be?
Aug 29, 2010 at 2:28 AM
DOCFIXIT
  • 18,828 POSTS
Hi
20 in is good is vacuum gague needle steady? does reading go up with slight throttle? Has compression been checked? engine timing good?
Let me know
Thanks for donate
Aug 29, 2010 at 7:40 AM
MIKEM367
  • 10 POSTS
The needle was fluctuating. I found some loose bolts on the intake manifold. thanks.
Aug 29, 2010 at 11:47 PM
DOCFIXIT
  • 18,828 POSTS
So that got it? running good?
Aug 30, 2010 at 7:02 AM
MIKEM367
  • 10 POSTS
Yes. I got this truck from a friend who said he recently rebuilt the engine so I should have known to go back over and check the torque on a lot of the bolts. All the intake bolts were loose. Some two turns loose as were the valve cover bolts. Running good now. Thanks.
Aug 31, 2010 at 1:27 AM
DOCFIXIT
  • 18,828 POSTS
Great news and good work
Aug 31, 2010 at 4:00 AM
