1989 Ford Bronco Transmission Oil Change
1989 FORD BRONCO
131,000 MILES • V8 • 4WD • AUTOMATIC
RONALDCONAWAY
I purchased a 89 Ford Bronco from a Sherriff's sale two weeks ago for 300 dollars. I drove it home, I was going to change the transmission fluid but an old school mechanic said to reuse my old ATF because I could burn up the transmission if I use new ATF. Is there any truth to that statement?
Sep 2, 2009 at 3:00 PM
BIGJIM79
  • 239 POSTS
NO this wrong. The new fluid will hold better pressure and you won't have any of the contaminants in the old fluid.
Dec 1, 2009 at 3:18 PM
