1989 Ford Bronco Tires in at top
123,000 MILES • V8 • 4WD • AUTOMATIC
EVERETT08
When ever I go in reverse the top of my tires go in twoards the motor alot. Like something heavy sat on the front of my truck. How do I fix that?
Sep 25, 2010 at 8:21 PM
  • 31,937 POSTS
Hi there,
Check that the wheel bearings are not loose first, jack up the wheel and there should not be any movement when rocking the wheel top to bottom, check this first.
mark (mhpautos)
Sep 25, 2010 at 9:21 PM
EVERETT08
thats what I thought at first but there is no movement top to bottom or left to right.
Sep 25, 2010 at 10:57 PM
  • 31,937 POSTS
Is there any movement in the steering knuckle?
Mark (mhpautos)
Sep 26, 2010 at 1:24 AM
EVERETT08
I can't find any slack or movement in any mechanical parts on the front end. Thats what has me so stumped. I can normally fix things, but this is way too complicated. I am hoping to get out of a thousand dollar repair bill. Im a welder not a doctor.
Sep 26, 2010 at 10:28 AM
  • 31,937 POSTS
I would now get someone who understands suspension components to watch for any movement when you load the suspension up in reverse, they should be able to see any movement.
mark (mhpautos)
Sep 26, 2010 at 4:53 PM
EVERETT08
I will try that, I appreciate your help.
Sep 26, 2010 at 5:04 PM
  • 31,937 POSTS
Let me know what you find,
Thanks,
mark
Sep 26, 2010 at 5:12 PM
BLUECOLLAR
  • 86 POSTS
My bet is the inner I-Beam bushings are bad. This happens allot when an older truck has an oil leak and leaks oil on the bushings. In time, the oil will deteriorate the rubber.
Sep 27, 2010 at 1:59 PM
