1989 Ford Bronco speedometer
163,000 MILES • 6 CYL • 4WD • MANUAL
BAMF
Hi i have a bronco 2, 2.9L
the speedometer stopped working, so i replaced the cable, still didn't work so i replaced the speed sensor......still doesn't work.....what do i need to check now?
Feb 17, 2009 at 11:49 AM
DOCFIXIT
  • 18,828 POSTS
Jack up rear wheels remove cable at trans start in gear does speedo gear rotate? if no remove bolt and clamp pull out plastic gear. Teeth worn replace.
Feb 18, 2009 at 4:08 AM
