1989 Ford Bronco no spark
108,000 MILES • V8 • 4WD • AUTOMATIC
DARKCROM
I was driving and the engine sputtered and failed. it will crank, but not turn over. I have no spark. I have replaced the coil, distributor cap, rotor, and ignition module. Do you have any other suggestions?
May 31, 2008 at 11:02 AM
MASTERTECHTIM
  • 4,750 POSTS
if you have power at the coil with the key on then the only other part in the ignition system is the pick up coil inside the distributor.
May 31, 2008 at 11:55 AM
