1989 Ford Bronco need to get my Bronco running again
ROY SLAUGHTER
  • 1989 FORD BRONCO
1989 Ford Bronco Four Wheel Drive Manual
I have a Ford Bronco that has not been started in 5 years and I was wondering what would it take to get it going again? My origanal problem was my altanator and because I have other vehicals I let it sit in the driveway. I would like to get it going again it ran great when it was running. What would be my first step in this process? Please help if you can.
Thanks for your time
Thursday, August 19th, 2010 AT 12:01 PM
Fuel -check the fuel pressure to rule out the fuel filter and fuel pump, then the coolant and oil-just to fire it up and then change it and then check the rest-don't move the vehicle to your satisfied that everything is coming in place-no overheating/knocking noises etc.
Thursday, August 19th, 2010 AT 4:48 PM
