1989 Ford Bronco it wont fire
EARLS_TONY
  • 6 POSTS
Electrical problem
1989 Ford Bronco 6 cyl Four Wheel Drive Manual
Ive got a 1989 ford bronco II . And we tore it down to put a new head gasket on the driver side . It was runnin good other than the water in the oil . But once we put it back together it wont fire . I put everything back right . So i thought it might have been the coil went bad and changed it but still nothing . Its got fire comeing into the coil but none comeing out . I thought it might would be the pick up coil in the distributor but i changed the whole distributor and still nothing . Have any ideas ? any help is greatly apprichiated .
Apr 18, 2010 at 2:03 PM
  • 110,248 POSTS
Have you checked the computer?
Apr 20, 2010 at 3:06 AM
EARLS_TONY
  • 6 POSTS
Honestly i dont know much about these newer models . How would you go about checking the computer ? thanks for the help .
Apr 20, 2010 at 3:04 PM
  • 110,248 POSTS
The easiest thing to do is take it to a nationally recognized parts store and have them scan it for you. Most will do it for free, so there is no money out of pocket.
Let me know what you find.
PS: I miss the older vehicles too.
Apr 20, 2010 at 4:26 PM
EARLS_TONY
  • 6 POSTS
Eh joe this is tony again . I just wanted to let you know that me and my dad finally figured out what was wrong with that bronco II . it was just a blowed fuse in the instrument panel . Thanks anyways for all the help .
Apr 22, 2010 at 3:24 PM
  • 110,248 POSTS
A fuse? Which one was it?
Apr 22, 2010 at 11:31 PM
EARLS_TONY
  • 6 POSTS
Im not for sure . My dad was the one traceing the wires . Call us up tonight after nine @ 870 821 0995. And ill let my dad tell you what we found and did .
Apr 23, 2010 at 12:39 AM
  • 110,248 POSTS
Hi:
I'm sorry, but I am required to do all work via this site. Can he explaine it to me?
Apr 23, 2010 at 10:25 AM
EARLS_TONY
  • 6 POSTS
Scratch that . I was partially right . But can you tell me where the distributor gets its fire from ? according to the book i got it says its supposed to be a red wire with a light green stripe . But its dead . And if you try to jump around it it acts like its dead shorted . Im begining to wonder if the computer has done got blowed . What you think ?
Apr 24, 2010 at 12:17 PM
  • 110,248 POSTS
That is the correct wire. If dead, have the computer checked.
Apr 24, 2010 at 1:52 PM
