1989 Ford Bronco injectors
80,000 MILES • 6 CYL • 4WD • MANUAL
PAPAWRALPH
This is a Ford Bronco 2
I have tried everything and talked to a few people and we are all stumped.
I have no fuel coming from the injectors.
It has new fuel cell and has good pressure
there is no pulsating through the injectors
and is not letting the fuel through
Mar 16, 2008 at 12:48 PM
BLACKOP555
  • 10,386 POSTS
hook up a noid light to each injector connector and crank the engine, does the light flash?
check to see if you have voltage at the connectors with the key on.
post back.
Mar 16, 2008 at 1:50 PM
